bitomaxsp
Member
Got my first broken Pioneer recently. Before that i didn't even know AK is exist
I started googling restoration project to see what people are facing with while restoring SX-580/590 series. Finally i ended up here and decided to make a thread.
I got 590 with complains that left channel has hums. Also no side panels. Scratches all over the body. Someone tried replacing STKs but very not professionally. Also touched FETs (tried to solder them or replacing, who knows). Anyhow, i powered it up and attached my speaker. Checked both channels and it seems hums in both of them. Not sure about at which frequency since i tried usual music.
Then i decided to check PSU voltages. 13.6 was okay. But 41.7V was 7V!. I am like: hmmmm. I postponed.
Then when i had time again, i decided to debug a bit. Warmed up amp a bit and 41.7 bus was already 13V. The more consumers i removed from that bus the more voltage has grown. Nothing pointed to bad transistor. It was original (opposed to 13V which was already changed). I solder it out and omg) transistor was a diode between collector and emitter. Check all the PSU caps, they lower than needed.
Oh! The main thing! Voltage on STKs power supply is symmetric and 29V(-29V).
The one that should be 1.2(-1.2)V is 0.8 and -0.8. Not sure it good or not, but it was with bad PSU though. I'll recheck it once i'll restore the PSU.
So far i have some stuff on order and continue when it arrives.
Also I ordered 10 pieces of STK-0050 replacements from this thread: https://audiokarma.org/forums/index.php?threads/stk-0050-replacement-for-sx-780-and-others.721181
I only need 2 of them.
