How to help keep your sound system healthy:
Keep your equipment clean and allow room for it to breath, top bottom and sides!
Keep your speaker wire runs only as long as needed (none extra coiled up laying around)
Use 12, 14, 16, or 18 ga speaker wire, none less.
Make certain there are no wire "cat" wiskers between speaker terminals (NEAT INSTALL), no extraw long bare leads in your hookups.
Inspect your runs and be cetain that there are no furniture nor nails cutting into your speaker wiring.
As stated above by use ONLY one set of four ohm speakers on your system at a time.
Keep the teens away from your stereo.
Keep the volume LOW!, 40 to 100 watts is not a lot of volume decibles in most bookshelfs speakers unless they contain horns and doubling the power to eighty watts only gives a baraly percievable amount of volume increasel (2x power = 3dB sound level increase).
Accept that the instrument is not immortal and has a life, and sometimes things just fail.
