goat67
Addicted Member
I installed the new 560 ohm resistors on pin 1 to 4 and pin 6 to 4. On the GWH-101 board I installed new capacitors 1, 2, 7, 8, 9, 10, 13, 14. Also new transistors Q1 and Q2 which came as 2 SA992 that I soldered the 2 emitter leads together which gave me a 5 pin hook up as per the kit instructions. Also replaced Q3 and 4. I had screwed up the Q1 and 2 install and redid them and checked everything. As far as I know or can tell every new component is correctly installed. I went ahead and gave you the pin readings for Q1 even though not requested.
Board Pins Readings
1. 31.7v
3. -32v
5. 32v
7. -32v
12. -35.5v
14. 34v
28. -35.5v
29. 34v
Q4
E -35.3v
B -35.3v
C 9.0v
Q2
E -34.4v
B -34.3v
B -34.4v
C -35.0v
C -34.4v
Q1
E -34.5v
B -33.8v
B -34.5v
C -34.4v
C -35.3v
Pins with resistors
Pin 2 12.0v
Pin 4 9.9v
Pin 6 8.7v
All 3 are positive readings.
Thanks for all your time and help.
Is that a typo on how you installed the resistor I hope so.
Why did you install all these new parts?
When did you install them?
You say you screwed up Q1 and Q2 did you get new transistors to replace these? It looks like these are shorted or installed incorrectly. How did you screw up.
There should be no need to solder the pins together the circuit board has been made to allow each emitter lead to be soldered in individually look at the image above
I would like images of this board component side to verify installation I need to see clearly how the transistors have been installed and the capacitors.
What are the part numbers of the transistors you installed? Where did you get them?
Is there anything else you have done and not mentioned.
I would like you to get readings of the power pack pins 1 thru 7 to ground both channels dcv
and the voltages for Q1 and Q2 like this so I can identify each of the transistors
Q2 is a transistor pair in one package two transistors with a common emitter
Q2a
E
B
C
Q2b
B
C
