toymanmsp
There are places a KSC2383 is better than a KSC1845 but this is not one of them. The KSC1845 has higher gain for better response in that application in a voltage regulator.
Lift one end and measure the resistors R2, R3, R4 on that board.
Fuses should be checked with your ohmmeter, unsolder one end (or the wire to it) because the transformer winding can fool you into thinking it is not open, when it really is. Mouser sells fuses with tails on them, or you can add a fuse holder.
Have you replaced C7 and C6?
greetings, I saw your recent message, I'll reply shortly.
I've checked the resistors and the fuse. R2 and R3 both measured 1.5Kohm and R4 measured 3.3Kohm, so these look ok, per the SM.
I did confirm that the fuse is blown. As a next step, I'm assuming that I can resolder the resistors and work to replace the fuse? I left the pins in place and think that I can get the fuse soldered in. It's the .5A fuse, could this blown fuse be preventing the relay to come out of protection mode?
The little chinese multi-function unit I have sometimes gives negative ESR values
