I finally received my parts from Mouser and installed them last night. The CRD solution worked and Q20 is now showing correct voltages!
There still is a problem with some of failed test point initially reported. A couple readings have improved
Q20 = B: -39.45v, C: -50.3v, E: -38.7v
Q19 = B: +39.2v, C: +48v, E: +38.6v
Q25 = B: +13.87v, C: +23.6v, E: +13.27v
C307: +38v (good)
C308: -38.8v (good)
R238 top: -38.8v (good)
R238 bottom: -30.01v (s/b -17.1v)
R237 top: -38.8v (good)
R237 bottom: -29.57v (s/b -17.1v)
Q6 = B: -0.549v, C: +38.7v, E: +0.01v
Q5 = B: -0.549v, C: +38.7v, E: +0.01v
*Q6 & Q5 were previously replaced with KSC1845FTA before Q20 repair
R240 bottom: -0.549v (s/b -13.5v)
R239 bottom: -0.547v (s/b -13.5v)
Q10 = E1: -37.7v, C1: -36.6v, B: -37.1v, C2: -37.1v, E2: -37.7v
Q9 = E1: -37.7v, C1: -37.7v, B: -37.1v, C2: -37.7v, E2: -37.85v
(*Q10 &Q9 are the original 2SC2291)
Q7 = B2: +0.01v, C2: +0.01v, E: +0.6v, C1: -37.1v, B1: +0.01v
Q8 = B2: +0.01v, C2: +0.01v, E: +0.6v, C1: -37.1v, B1: +0.01v
(*Q7&Q8 are the original 2SA979)
Q15 = B: +38v, C: +6.77v, E: +37.6v
Q16= B: +38v, C: +6.61v, E: +37.61v
(*Both 2SA912 were replaced with KSA1013YBU before Q20 repair)
Q13= B: -38v, C: -4.17v, E: -37.2v
Q14= B: -37.8V, C: -4.19v, E: -37.2v
(*Both 2SC1885 were replaced with KSC2383 before Q20 repair)
Q11= B: -36.95v, C: -4.17v, E: -37v
Q12= B: -36.8, C: -4.20, E: -37.2v
(*Both 2SC1775A were replaced with KSC1845 before Q20 repair)
Q28 & Q29 (2SK34): one was replaced with J113, the other with BF256B which is what i had onhand before Q20 problem was fixed. I dont have any more BF256B. Should i replace both to match with new J113 or CRD202? Would this cause the problem with some of the incorrect voltages above?
