mattsd
I'm recapping a Pioneer SX-850 for my dad, and I have put together the lists of all the boards except the tuner board. Markthefixer, could you confirm all this? I had a question about a few caps, they have in the description "NL", basically it reads like this: Electrolytic (NL), instead of just electrolytic. They are all CEANL's, but I was wondering what that means. Also there are three on the power supply board that did not have a cap type listed, but I believe that they are general purpose caps, so I put UPW's as the replacements.
Anyway, here is the lists, complete with the subs for the known noisy transistors (2sa725 and 726). Correct me if there are others in this receiver, but those are the ones I know about.
Power Amp Board
AWH-059: C1: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWH-059: C2: 2.2uF 25v CSSA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWH-059: C3: 1uF 25v CSSA: 647-UKL1H010KDDANA 1uF 50v
AWH-059: C4: 1uF 25v CSSA: 647-UKL1H010KDDANA 1uF 50v
AWH-059: C5: 33uF 16v CEA: 647-UPW1C330MDD 33uF 16v
AWH-059: C6: 33uF 16v CEA: 647-UPW1C330MDD 33uF 16v
AWH-059: C11: 330uF 10v CEA: 647-UPW1A331MPD 330uF 10v
AWH-059: C12: 330uF 10v CEA: 647-UPW1A331MPD 330uF 10v
AWH-059: Q1: 2SA726: 512-KSA992FBU
AWH-059: Q2: 2SA726: 512-KSA992FBU
AWH-059: Q3: 2SA726: 512-KSA992FBU
AWH-059: Q4: 2SA726: 512-KSA992FBU
Power Supply Board
AWR-101: C10: 470uF 80v ACH-038: 647-UHE2A471MHD 470uF 100v
AWR-101: C11: 470uF 80v ACH-038: 647-UHE2A471MHD 470uF 100v
AWR-101: C12: 2200uF 35v ACH-060: 647-UPW1V222MHD6 2200uF 35v
AWR-101: C13: 1000uF 25v CEA: 647-UPW1E102MPD6 1000uF 25v
AWR-101: C14: 220uF 10v CEA: 647-UPW1V221MPD6 220uF 35v
AWR-101: C15: 470uF 63v CEA: 647-UPW1J471MHD 470uF 63v
AWR-101: C16: 47uF 16v CEA: 647-UPW1V470MED 47uF 35v
AWR-101: C18: 47uF 50v CEA: 647-UPW1H470MED 47uF 50v
AWR-101: C19: 47uF 35v CEA: 647-UPW1V470MED 47uF 35v
AWR-101: C20: 100uF 63v CEA: 647-UPW1J101MPD6 100uF 63v
AWR-101: C21: 47uF 16v CEA: 647-UPW1V470MED 47uF 35v
AWR-101: C23: 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
Equalizer Amp Board
AWF-011: C1: 1uF 25v CSSA: 647-UKL1H010KDDANA 1uF 50v
AWF-011: C2: 1uF 25v CSSA: 647-UKL1H010KDDANA 1uF 50v
AWF-011: C7: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWF-011: C8: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWF-011: C11: 3.3uF 25v CEANL: 647-UKL1H3R3KDDANA 3.3uF 50v
AWF-011: C12: 3.3uF 25v CEANL: 647-UKL1H3R3KDDANA 3.3uF 50v
AWF-011: C17 100uF 35v CEA: 647-UPW1V101MPD 100uF 35v
AWF-011: C18 220uF 25v CEA: 647-UPW1V221MPD6 220uF 35v
AWF-011: Q1: 2SA725: 512-KSA992FBU
AWF-011: Q2: 2SA725: 512-KSA992FBU
Switch Assembly Board
AWS-094: C1: 220uF 6.8v CEA: 647-UPW1A221MED 220uF 10v
Flat Amp Board
AWG-038: C1: 2.2uF 50v CEANL(NL): 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-038: C2: 2.2uF 50v CEANL(NL): 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-038: C5: 4.7uF 50v CEANL(NL): 647-UKL1J4R7MDD 4.7uF 63v
AWG-038: C6: 4.7uF 50v CEANL(NL): 647-UKL1J4R7MDD 4.7uF 63v
AWG-038: C13: 220uF 35v CEA: 647-UPW1V221MPD6 220uF 35v
AWG-038: C14: 220uF 35v CEA: 647-UPW1V221MPD6 220uF 35v
AWG-038: C17: 10uF 25v CSZA: 647-UKL1E100KDDANA 10uF 25v
AWG-038: C18: 10uF 25v CEZA: 647-UKL1E100KDDANA 10uF 25v
AWG-038: C23: 4.7uF 50v CEANL(NL): 647-UKL1J4R7MDD 4.7uF 63v
AWG-038: C24: 4.7uF 50v CEANL(NL): 647-UKL1J4R7MDD 4.7uF 63v
AWG-038: C25: 100uF 10v CEANL(NL): 647-UKL1A101KEDANA 100uF 10v
AWG-038: C26: 100uF 10v CEANL(NL): 647-UKL1A101KEDANA 100uF 10v
AWG-038: C27: 100uF 50v CEA: 647-UPW1H101MPD 100uF 50v
AWG-038: Q5: 2SA725: 512-KSA992FBU
AWG-038: Q6: 2SA725: 512-KSA992FBU
Tone Amp Board
AWG-039: C13: 2.2uF 25v CSZA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-039: C14: 2.2uF 25v CSZA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-039: C15: 2.2uF 25v CSZA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-039: C16: 2.2uF 25v CSZA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-039: C19: 100uF 10v CEANL(NL): 647-UKL1A101KEDANA 100uF 10v
AWG-039: C20: 100uF 10v CEANL(NL): 647-UKL1A101KEDANA 100uF 10v
AWG-039: C21: 47uF 35v CEA: 647-UPW1V470MED1TD 47uF 35v
AWG-039: C22: 47uF 35v CEA: 647-UPW1V470MED1TD 47uF 35v
AWG-039: C23: 2.2uF 25v CSZA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-039: C24: 2.2uF 25v CSZA: 647-UKL1H2R2KDDANA 2.2uF 50v
AWG-039: C25: .22uF 35v CSZA: 667-ECQ-V1H224JL2 .22uF 50v
AWG-039: C26: .22uF 35v CSZA: 667-ECQ-V1H224JL2 .22uF 50v
AWG-039: C29: 10uF 25v CSZA: 647-UKL1E100KDDANA 10uF 25v
AWG-039: C30: 10uF 25v CSZA: 647-UKL1E100KDDANA 10uF 25v
Protection Board
AWM-062: C1: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWM-062: C2: .22uF 10v CSSA: 667-ECQ-V1H224JL2 .22uF 50v
AWM-062: C3: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062: C4: 330uF 6.8v CEA: 647-UPW1A331MPD 330uF 10v
AWM-062: C5: 4.7uF 25v CEA: 647-UPW1V4R7MDD 4.7uF 35v
AWM-062: C6: 100uF 16v CEA: 647-UPW1V101MPD 100uF 35v
BOM list:
647-UKL1H2R2KDDANA | 10
647-UPW1C330MDD | 2
647-UHE2A471MHD | 2
647-UPW1V222MHD6 | 1
647-UPW1E102MPD6 | 1
647-UPW1J471MHD | 1
647-UPW1H470MED | 1
647-UPW1J101MPD6| 1
647-UPW1V470MED | 3
647-UKL1H010KDDANA | 4
647-UKL1H3R3KDDANA | 2
647-UPW1A221MED | 1
647-UPW1V221MPD6 | 4
647-UKL1J4R7MDD | 4
647-UPW1H101MPD | 1
647-UKL1A101KEDANA | 4
647-UPW1V470MED1TD | 2
647-UKL1E100KDDANA | 4
667-ECQ-V1H224JL2 | 4
647-UPW1A331MPD | 6
647-UPW1V4R7MDD | 1
647-UPW1V101MPD | 3
512-KSA992FBU | 8
All were in stock at the time of posting.
Edit: Also, for the replacement of the main filter caps, any recommendations?
Power Amp Board
Power Supply Board
Equalizer Amp Board
Flat Amp Board
Tone Amp Board
Protection Board
BOM list:
647-UPW1C330MDD | 2
647-UHE2A471MHD | 2
647-UPW1J471MHD | 1
647-UPW1H470MED | 1
647-UPW1J101MPD6| 1
647-UPW1V470MED | 3
647-UPW1A221MED | 1
647-UKL1J4R7MDD | 4
647-UPW1H101MPD | 1
647-UPW1A331MPD | 6
647-UPW1V4R7MDD | 1
647-UPW1V101MPD | 3
512-KSA992FBU | 8
