Wow, you are really putting in the hours here.
OK, identify all the interrelated components around those 8 transistors, and get a can of keyboard duster.
COOL each component individually, do NOT BLAST them hard, they will get cold enough to form condensation, ice, or white stuff - which we do not want.
Try to shield the non-cooled components with some cardboard etc...
Sometimes a small non-conducting tube like a large straw can isolate a component from all others.
WATCH the idle current like a hawk. when it starts to dip back to the 55mv you are getting close.
To confirm, when THAT component is swapped to the other channel, the problem will move.
You MAY see other cooling effects on innocent components. We don't want to drive them to extremes.
DO NOT cool down the transistors - we swapped them without changes, but the temperature changes WILL induce significant masking changes in them. Changes we are not interested in chasing.
The idea is to cancel out that 2 minutes of warm up, not to turn the area into the Antarctic.
The technique works, we once found a temperature sensitive quartz crystal for an oscillator in a receiver doing this. I would have NEVER thought of THAT otherwise.
You CAN use a hairdryer to reverse the cooling, but again, take it easy, if it's too hot to touch, it's way too damn hot for this situation.
This is probably faster and easier than taking a gazillion voltage measurements.
I say keyboard duster, because it's far less expensive and much less aggressive than freeze mist. But it WILL freeze if someone gets enthusiastic with it.
