Jcamp
Hello,
I need some help with a SX-950. I received it with the following components blown
Four power transistor - Replaced all with "original" 2SB557/2SD427 from eBay
Both 2SB536
One C1628
Both Bias pots blown
150 ohm R40,R39
I have replaced these transistors
2SB536 with KSA940
2SD381 with KSC2073
2SA818 with KSA1142
2SC1628 with KSC3503
Small 2SA726S all test good
Diodes and STV4H all test good
On the power supply board AWR101 I replaced these blown components
2SA720 with KSA1013
2SD313 with KSC2334Y
2SC1318 with KSC2690
Three 150 ohm resistors
Tested all voltages from the power supply board and matched service manual. I then powered up with no power transistors and relay clicked in and no smoke. I installed the power transistors triple checking placement and pinouts, also tested for shorts and tested the transistors before installing and everything looked good so I powered up and the 150 ohm resistors started smoking. I removed the power transistors to test and they all went short and open!. The transistors I ordered looked very suspicious, they were much lighter and thinner than the originals and the silk screening rubbed off of them very easy. I ordered eight new MJ21194G and MJ21193G to replace them. I don't want to install them until I am 100% sure the amp board is working correctly.
With no power transistors installed I am now getting 50v between collector and emitter and also collector and base! same thing on the negative side -50v between collector and emitter/collector and base (I have pulled all the transistors I replaced on the board to test and they all survived. I have spent so many hours trying to figure this out and I desperately need help.
I really appreciate any help!
Thanks
Both 2SB536
One C1628
150 ohm R40,R39
2SB536 with KSA940
2SD381 with KSC2073
2SA818 with KSA1142
2SA720 with KSA1013
Thanks
