On it - ordering one Omron and a spare from Newark (they ship faster to Canada here) - getting the LY with standoffs noted in another thread. Thank you.Just replace the relay. Cleaning them is a waste of time and I don’t recommend it.
Thank you for responding Mark. Have seen many threads you have provided your sage advice in. Out for dinner now. Have not checked if it is a multi-voltage unit at this juncture but will when I get home. I used to sell hifi overseas in the military market many many moons ago and a lot of that gear came back to Canada here so it is entirely possible - yes, still on dbt. Didn't want to pull it off given it still had a fair bit of glow on the bulb. Didn't want to risk frapping something before someone wiser than I provided a responseThe salient fact is that the 51v regulated is only 37, while the series regulator is being fed 39v, and the AC off the transformer is 33v.(pin 25 & pin 26)
WHY this is happening... are you still on DBT? Is it a multi-voltage unit? If a wire broke in the primary of a multi-voltage unit, it could result in this.
The 7.5vac lamp circuit is monitored by the protect to determine turn-on and turn off status. These AC voltages aren't enough to say "I'm ON !!"... to the protect board. (pin 12, what is the AC voltage?)
Meant to say it is 120 VAC 60 Hz 370 watts only. I edited the previous response to say it was single voltage unit. Anyway I gather that the transformer output needs to be at least 50V off the feed to the D1-4 Bridge voltage regulator? Still trying to process how it is that the feed AC voltage is close to the same on both taps and they are close to the same? Is it because I still have it plugged to the DBT and somehow current limiting is limiting voltage too?Those missing AC secondary voltages in the manuals always REALLY irked me.
I haven't seen many transformers actually fail, but I have seen a few that are fed wrong or strangled.
Just found this thread with your input. At first glance it looks pretty similar so will have a read through so as not to reinvent the wheel: https://audiokarma.org/forums/index.php?threads/pioneer-sx-950-power-measurement-issues.917986/Those missing AC secondary voltages in the manuals always REALLY irked me.
Once the power output transistors are installed and idle currents tested ("tickling the dragon's tail"), there is no point in leaving the DBT connected.
Thought as much. I actually set the DC offset and bias when the receiver was off the DBT. Reading that previous thread I have pulled the PS fuses and am going to try to get AC Voltage readings from the board inputs. Will do it 1st on DBT then risk going off DBT. So far I have not put the shunts back in between the pre out and main in sections of the receiver. Have also got the speaker selectors switched off to isolate the amp side as best I can. Taking baby steps me thinks....Yes. The DBT strangles the unit, although the more wattage of the DBT, the less the strangling. The larger wattage doesn't really affect the vital function of the DBT, because when the DBT is bright, the unit is super strangled.
Since you said that idle current checked ok (on dbt no less) be sure the idles are dialled down to zero, then get off the DBT.
IF idle current is set on DBT, AND LEFT AT THAT SETTING, when the unit is plugged into the wall directly, the idle currents will be wayyyy too high. Perhaps damagingly high.
Remember, the unit was being strangled (ON dbt) , and as the idle current (on dbt) is turned up, the strangling becomes more pronounced.
Thanks agaon for the feedback. Having trouble deciphering your formula but will try to think it through.I have a problem with your entries,, you use a dash as a separator, but there are also negative voltages to be recorded. I assume dash space is a separator while dash number is a negative voltage.
2 & 3 are the function lamps, and if they have been changed from the 50mA incandescent lamps there will be a difference.
otherwise pins 27 & 28 feed ac to D9 & D10 through FU4 & FU5 to C12 1000uf / 35v
Since the 13.5v at pins 4 & 5 is ok, I suspect a problem with R20. R21, R22, Q9, Q10, C14 & or C13. See how stable the base voltage of Q10 is.
It should be mumble mumble {13.24 + 0.6 = 13.8 13.8 x (R22/(R21 + R22))) = 6.325 6.325 - 0.6 - 0.6 = 5.125 } 5.125 at pins 2 & 3 / base voltage of 6.325 .
Offset will be different, the power supply voltages changed.
