mcdoug3721
Verify Q2 KSC2690 installed correctly as the leads are ECB while 2sc1438 is BCE.
Ignore ^^^^ both are ECB!
These look OK, however there is 149mv DC on right channel output. Amplifier adjustments on page 25 of service manual, center voltage and idle current, should be performed at some point.here we go
Thanks for all your help
pin 1 21.40 v Ac
2 -49.60 v
3 0v
4 12.79v
5 0.149v
6 0.103v
7 0.067v
8 0.021v
9 13.22v
10 68.6v
I will check voltage but does these seem right to you. i did get a bit confuse with the pinVerify Q2 KSC2690 installed correctly as the leads are ECB while 2sc1438 is BCE.
Looks OKI will check voltage but does these seem right to you. i did get a bit confuse with the pin
R13 is giving me 1.6 K which is good i thinkDid you replace C1? Test resistance of R13.
Thanks for all your help, should i remove the relay and give it a good clean ???OK. Check that C1 is installed correctly.
48V on coil and 0V+- on pin 4 of PA3004 relay should be engaged (out of protection) as I see it. Someone else with more experience with this protection circuit may want to add/correct this assumption. Given that there is only 13V on coil it seems either the coil or D3 at this point.
If excessive DC is causing the issue, disconnecting pins 4, 5 and 8 on protection board will disconnect outputs from the circuit and the relay should click.
You can check this thread: https://audiokarma.org/forums/index...80-protection-relay-kicking-out.834334/page-6
Disconnected pin 4, 5 and 8 and still no click . So it must be the Relay .Relay may be shorted or bad. It can be tested out of circuit with 48V DC across the appropriate pins.
I would disconnect pins 4, 5 and 8 on protection board as a final test. This will disconnect the amplifier outputs and any DC voltage there may be. You have 145mv on one channnel which is high but not high enough to prevent the relay from engaging in my opinion. If relay clicks, you need to address the DC offset by preforming the amplifier adjustment procedures. These procedures need to be done once everything is sorted out regardless.
