Brivan
Well-Known Member
That was my assumption - by leaving the jumpers out, I was eliminating everything before the amplifier boards. And those were the only things I physically moved before the problem started. This morning, I moved wires, pressed on boards, etc - all while the relay was cycling, but I could never physically move anything that would definitely affect the relay cycle. One thing to note - the longer I leave the receiver on with the relay cycling, the more sporadic the cycling becomes - it might run for several minutes or only a fraction of a second. Since it's staying engaged for longer periods of time, I'll try to get some voltage readings and will post them. BTW I do have another "good" protection board coming from Ebay. I took voltage readings at the speaker terminals while the relay was engaged - both sides are at .1 - .2 mV.
