The relay has four sets of contacts, two for each channel, in parallel. If the contacts on one channel are damaged and the other channel's contacts are not damaged, it will only affect the channel with the damaged contacts. The other channel will be normal. The prime indicator that it is the relay contact problem, is that turning up the volume cleared up the noise. The higher voltage breaks down the damage on the contacts temporarily, letting the signal through. Cleaning the contacts will clear the problem for a short time, but once they are damaged they will not last long. Replacing it is the best option for a long term repair.and it only affects one channel?
and if so, why does it affect a channel?
change it and try?
I was going to change transistors Q25, Q20, and Q19
I change them too?
helloI saw those replacements of the stk-0050 in some posts , but here in Argentina I don't get them, but I saw here a Chinese versions of the stk-0050, maybe I bought some for replacement.
I have been testing the sx780 for 3 days and the noise did not return, later I will review the darlington heatsink compound,
could you tell me the theory why only one channel comes out with noise?
Maybe that poor power supply affects the darlington of the right channel because it is more deteriorated
Thank you very much for your help, I appreciate it very much
YesDid you replace the protection relay?
could it be caused by the speaker selector (A or B) ???
It seems that in the service they changed those transistors
It’s very unlikely that they changed the dual transistors.
try a hair dryer and freezer spray to check each component .
heat and or cold will often show up failed components .
on another note any chance of you posting an audio file of the noise ?[/QUOTE
impossible to replicate or to know when it happens
