Pivot to spindle distance and overhang....
I'm wondering about some things and not quite sure I have a good understanding about the relationship between manufacturer recommended pivot to spindle distance and cartridge overhang.....when using the right protractor for your table, why are either of those factors even necessary considerations, or are they?
When setting the null points, one uses the screws in the cartridge/headshell to either push the cart forward or back in order that the stylus is centered on the null points. The only reason I can imagine the pivot to spindle distance might come into play would be if this adjustment can't be made and the tonearm base needs to be moved either inward or outward to accommodate putting the cartridge in the proper position so that it might be adjusted and fall within the positions of the null points.
So, could it be that the reason for the manufacturer even giving the pivot to spindle and overhang measurements is to make setup possible without a protractor? That seems to me the only plausible explanation but I hope others here can chime in and further illuminate the subject for me. Once you have the stylus hitting the null points dead-on, what importance are overhang and pivot to spindle distances?
Thanks!
Thanks!
