Hey-o everyone,
I'm currently working on repairing a PL-41, and a lot of the posts here have been super helpful (thrust pad, replacement belt, cartridge recommendations etc.), thank you.
The only problem is, my PL-41 doesn't have a platter. I have access to a machine shop, so I figured I could just machine one out of some 300mm x 10mm aluminium round stock as per http://akdatabase.com/AKview/albums/userpics/10004/Pioneer PL41 Owners.pdf . (Actually the original is 310mm diameter and doesn't specify the thickness, I calculated the thickness based on density of aluminium and quoted mass of 2.2kg to be approx 10mm). Just wondering if anyone who owns a PL-41 with an oem platter would mind measuring it for me, specifically:
- Outer diameter
- Real thickness
- Mounting bore diameter (also, is it tapered or anything fancy? Or any other clever mounting strategies? Does it just rely on a friction fit with the capstan?)
- Positions and diameters of the finger holes (why not)
- The thickness including the mat ontop (if I make the platter too thin/etc, I can make a cork or other material mat that it thicker etc.)
- Anything else of note I might have missed
Cheers all,
Nick
- Outer diameter
- Real thickness
Cheers all,
Nick
