the_burmese
That was a great suggestion. I measured the inner spline diameter and it is smaller (2mm) than that of the main shaft (3mm). So it would be too small to fit in the current bore (3mm). Only two way is to reprint them with 4mm bore (which would fit the sleeve) or 2mm which would fit the inner spline.
Going to try opening the bore to 4mm with a Dremel. If that doesnt work out well, will try to print again. Thanks!
