PL-570 Restoration
Hello, I came here looking for information about the gear for the pioneer pl-570 turntable. I found an entry by the_burmese regarding the gear wheel project. Has anyone here used the project of colleague? Is there a chance to get the project and print it out yourself?
SM stated PN as SE302A which is a NEC laser diode. Datasheet says it is 940nm so it is IR mode.
I found this part that match "mostly" in size, power and wavelength. Will see if it would be a good solution.
https://www.digikey.com/en/products/detail/inolux/INL-3AHIR15/10384794
Was this a good part for the replacement of SE302A? DId you get your auto return issue fixed? I'm trouble shooting an auto return issue on a pioneer pl 570 and I think SE402A might be the problem.
