Segasonic91
I have recapped most of this amp now and changed all the transistors. There was a ridiculous comedy of erros on my part when testing after getting the relay clicking on, which I will not go into because it makes me mad when I think about it, lol.
The big booboo I made was installing a cap backwards (have NEVER done that before!) and it popped. There was also a spark on the power board, but not sure where. Thankfully I had the cover on! Always pop it on first. Needless to say, no more relay kick. So now I do not know what is wrong with it. Any clue as to where I should start? I am assuming a short somewhere, but no clue WHERE.
I was testing the resistors on the board today and there does appear to be dead and open ones, on the eq board, the power board and the volume board. I am just not sure if these are all correct. I am testing in circuit. Could there really be that many resistors dead or open? Could it also be that they were already dead or open? Or would that have caused no relay kick?
Also, there was a diode I though may be dodgy and I was going to replace it. It is a 500mW diode and I could only find a 1W replacement. Does the wattage have to be exact? Or can the wattage be higher?
Thanks!
Thanks!
