petehall347
the brandy coffee man
check resistors ... r775 r774 in the right channel ...
with the unit unplugged from the wall check resistance of the resistors above ..
they should read 0.24 ohms .. your meter may say more like nearly 1 ohm .. this is no problem though as you can see if all 4 resistors look about the same resistance ...
