The spacing of the leads can be different on different capacitors. If all the other dimensions are the same, they might match up just dandy, but you never know. Just like 'standard' capacitance values, the standards have changed over time.
https://en.wikipedia.org/wiki/Electrolytic_capacitorI'm still learning the terminology. What do you mean by electrolytics?
A Realistic STA-2080 I worked on had a fubber/foam spacer glued to the top of one of the caps to keep the top cover from hitting the cap directly. Could it be remnants of this?
Hopefully those caps are discharged pretty quickly after shut down through design in the circuit (bleeder resistors), you can check them with a digital multi meter (DMM) to see if they are retaining a charge before doing the replacement, if they are carrying a charge you can take something like a 2 watt resistor of a value of something like 170 kohms and place across the positive and negative terminals of the capacitor for a few minuets to discharge what remains, then do the same with the second capacitor.
Not sure how much you know and you may already be aware, but I'll mention that you will have to set the meter to read DC when checking the caps for charge.Thanks. I'll do that.
Thank you. I know a little bit and I'm still learning. I did know to set it for DC. When testing the caps, is it possible to test from them from the bottom of the board? There's very little room to get the DMM probes in there.Not sure how much you know and you may already be aware, but I'll mention that you will have to set the meter to read DC when checking the caps for charge.
Worth looking over all the other electrolytic caps for signs of bulging or leaking while you are at it.
Hope it goes well for you.
Test with probes placed on the positive and negative terminals of each cap, so that would be on the underside of the circuit board?Thank you. I know a little bit and I'm still learning. I did know to set it for DC. When testing the caps, is it possible to test from them from the bottom of the board? There's very little room to get the DMM probes in there.
I was thinking I could test the connections on the underside of the board where the terminals are soldered? Unless I'm misunderstanding, I can't get to the terminals while the caps are still on the board.
I'm a little confused, if you can test on the underside where the terminals poke through the board and are soldered, that is fine.
Sealant?The reason I asked about the bottom is that the caps have some sort of sealant at the bottom so there's nowhere for me to access the terminals.
Sealant?
Could you upload a picture?
You're going to have to access the underside no matter what. That rusty capacitor, whatever the cause of the rust, needs replaced.Thank you. Do you see what I was saying about not being able to access the terminals with a DMM? In other words, the only way to test these is to access the underside.
