No Transistors ,muovimies,Andyman
Pretty clear answers ,lots of interesting info, thank you !
1. What about the material ? Plywood plates MDF plates or hardwood ? I spotted manufacturers for all three variants
The alternative of doing it myself is out of question for various reasons
2. Another question :how bad is that bearing problem in the 1229/1219?
That means I should ask the seller in what shape is the bearing and also the motor gommets ... and not be interessed as much in the plinth , since sooner or later I'll probably change it...
3. Should I understand that the main bearing construction is some limiting factor in SQ and I should search maybe another type of Dual ? 621 or 721 ? Or the things are not as radical ?
I've built 3 plinths for various TTs, I think all the materials you mentioned can work well. It's really a bit of a black arts to be honest, but I don't think you'd go wrong with any of the materials you mentioned.
I've had no issues with the grommets or vibration from any of the three 1229 motors I've encountered, that's not a large sample size but enough for me to think it's probably not going to be an issue. As for the main bearing, the "problem" is the design - because of the way the changer mechanics work, instead of using a point bearing or whatever the right term for it is (this is the type of bearing you find in pretty much every TT apart from changers) it's constructed a bit differently and uses a bearing race at the bottom. I wouldn't say the issue is radical but I also don't think this type of bearing can ever be as good as a good point bearing. Friction is not an issue, all Dual bearings of this type I've seen have been very freely spinning, but they tend to be a bit more noisy - maybe I'm missing some servicing magic, but if so, to me that again speaks to the bearing design not being as good, because a trained ape could service a typical TT bearing without issue
Now keep in mind "noisy" in this case is a very relative term, you shouldn't hear any noise from the bearing unless cranking the volume very high, or listening to the spinning TT very closely / using a stethoscope or similar. There are a lot of very happy Dual owners out there, and many people prefer the idler Duals to their belt drive / DD tables despite the bearing. With any TT the condition of the bearing is very important. Personally I believe a good platter bearing is the heart of any turntable, and improvements in this area can sometimes yield surprising sonic benefits, but these are mostly subtle.
The Duals are very enjoyable TTs and do sound good, and what they do well they do very well - to get similar drive and authority from a belt drive design for example, you'd probably have to pay pretty much for it and besides some rare sleepers. In the (roughly) same price range I'd rather go for a Lenco myself, but then to truly surpass the Dual you'd probably need to get rid of the stock tonearm and get something better, which means more cash or working some magic on the original. The Duals have their quirks with the mechanics, the 'cartridge sled' etc. but at the end of the day you get a lot of great turntable for your money and IMO most "typical" cheaper japanese S-shaped arms from the same time period are sonically a step backwards compared to the Dual arm. If you're not mechanically inclined or aren't interested in learning to be, I'd recommend to get it serviced by a pro or a dedicated hobbyist who knows what they're about. NoTransistors is one such guy in the US, if you're in Europe and want a Dual there are some places in Germany (can't remember any names at the moment) who sell serviced ones for which I thought were very reasonable prices the last time I checked.
