Bob E. said:
Well, you really do want a good mechanical connection established either by crimping or wrapping...not only is the electrical connection better, the sturdiness of the joint is much improved and you also avoid cold solder joints. Solder is a much poorer conductor of electricity than a good mechanically-established joint.
--Bob
I'll admit that I still do it sometimes, but..... several months ago I recapped an old Tektronix scope from the mid 50's. Tek equipment from that era is probably the highest quality tube-based equipment ever made, period. There wasn't a wrapped connection in it anywhere.
It was really nice, because some of the caps were on rotary switches, in really, really inaccessible places. I just heated them up, hit it with the solder sucker, heated again and pulled the old parts out. I put the new ones in the same way they were originally. Things look as nice in there now as they ever did, and it was easy.
There is a persistent story about Howard Vollum, founder of Tektronix. He was an electronics enginneer or tech of some kind in the military during WWII. The U.S. military required wires to be wrapped at that time, I believe two wraps on everything. Howard apparently felt very strongly that this was a bad idea. After the war, at Tektronix, he insisted that it not be done. There was some contention with the military about this, because Tek scopes were not "mil spec". Based on his experience during the war, Howard felt that if there was a bad solder joint, you wanted it to fall off so you could find it, rather than poke around for two days looking for it, possibly while under attack. There was also less chance of breaking stuff while doing repairs. He held his ground, and eventually the military saw it his way, or at the very least bought a bunch of Tektronix oscilloscopes.
I rebuilt an old shortwave set recently, and because of it's military origins (sort of) I wrapped all the wires... almost. I just laid the wires through on the most fragile parts, like the wafer switches and the coil forms.
I had the coil stacks out of it three times before it was done. Nothing broken. I'm sure glad I didn't wrap those wires.
John
