ajcoates
Hey all - I purchased a TD-160 last week from an acquaintance for a high-side-of-fair price. I was disappointed to find that, while the unit was untouched from a mechanical standpoint and very clean, the bearing well was completely dry. Unsurprisingly, the bronze bushings were a bit worn and scratched.
I cleaned the well and decided it wouldn't be a bad idea to polish some of the marks with a felt tip/compound/low RPMs on my Dremel, just to see if I could salvage the existing bushings. They certainly cleaned up visually, but after a couple IPA flushes and oiling with the blue 3-in-1, I got a nasty grind when giving it a test spin. Attached a video of this below!
Have any of you guys successfully polished your Thorens bushings? If so, what polish and method did you use? I'm hoping this isn't a lost cause - thanks so much.
