Cylontymany
So can I use the 98 tweeters?
Edit: Sorry, in my original post I thought you were the OP.So can I use the 98 tweeters?
My RDO194's should be here in a day or two, can't wait to install them!!!!Not without modify your crossovers and I don't recommend using the RDO198 in your speakers.
I edited my post above. Yes, you can use the RD0198, but it requires a crossover modification.Interesting! Thanks. Its been awhile since I have researched this out. I thought that if I had a certain crossovers in my2Bs that the 98s were a possible drop in. I am glad I jumped in this thread and didnt purchase the 98s. May I ask why the 94s would be better than the 98s? Thanks again.
The OP has 2A's, so the RDO194 is really the only tweeter for his speakers. You have 2B's, so the straight swap is the RDO194, but with a modification to the crossover you can use the RDO198.Yes but why recommend the 94s over the 98s in the 2Bs?
Different drivers, different crossovers, different cabinets. 2A is 4 ohm nominal, 2B is 6 ohm. 2A uses the blade/blade cable and cannot be used with non-common ground amps. 2B uses the pin/blade cable and with the Polk AI-1 or Dreadnought isolation transformer can be used with non-common ground amps.
Ideal set up, 5 to 6 inches off the back wall, 6 to 8 feet apart, 3 feet from any side wall and no toe in.
Replace those nasty SL2000 tweeters with the RDO194. You'll thank me.
Adding spikes will tighten the bass and clean up the mids.
You don't want that or any Carver SS amp. However, his tube amps are stellar.
I have a CRown 1200 powering my SdA 2's..........I have an av receiver with pre-amp outputs to the amp.....These were great when I was playing my drums but know that I am "listening" to them they suk....load but no definition....using mp3 or cds into the receiver.........what do I need to do????Congrats! But you will need much more horsepower for those babies!
Silly question, but are you using the connecting cable between the speakers? And do do have them set up right? They are marked left and right.I have a CRown 1200 powering my SdA 2's..........I have an av receiver with pre-amp outputs to the amp.....These were great when I was playing my drums but know that I am "listening" to them they suk....load but no definition....using mp3 or cds into the receiver.........what do I need to do????
yep..........I'm thinking my receiver is garbage..Silly question, but are you using the connecting cable between the speakers? And do do have them set up right? They are marked left and right.
You said you were using the crown power amp connected to the AV receiver. Have you tried the AV receiver alone set to two channel, or stereo? You could connect your CD player directly to the Crown, if it has a gain control, connect your CD player directly to the Crown, using the gain control for volume. Who knows,.it may sound better that the AV.yep..........I'm thinking my receiver is garbage..
yes......it sounds better.......it's running a lot less power than with the ampYou said you were using the crown power amp connected to the AV receiver. Have you tried the AV receiver alone set to two channel, or stereo?
no bass/treble control doing it that way correct?You said you were using the crown power amp connected to the AV receiver. Have you tried the AV receiver alone set to two channel, or stereo? You could connect your CD player directly to the Crown, if it has a gain control, connect your CD player directly to the Crown, using the gain control for volume. Who knows,.it may sound better that the AV.
Yes. If the Crown has a gain control on the front like the Crowns I have, they can be used just like a volume control. Any line level source like a CD player, tuner, etc should drive it. I've ran several of my SS and tube power amps like that. A few times I added an input selector to switch between sources. You won't have any tone controls though connecting directly to the amp without the AV connected. Just using a volume control or autoformer, etc, is also called a passive preamp. No active to e Controls or line stage. Some people prefer this as there is less in the signal chain.no bass/treble control doing it that way correct?
He could be getting some Miller effect I guess having the AV connected to the amp if the amp has a gain control and its not set to full?Passive pre- there is your issue. The resistance from the volume control changes as you turn up the volume so it will change the sound going to the speakers.
I just want to here congas when I listen to Santana...........Yes. If the Crown has a gain control on the front like the Crowns I have, they can be used just like a volume control. Any line level source like a CD player, tuner, etc should drive it. I've ran several of my SS and tube power amps like that. A few times I added an input selector to switch between sources. You won't have any tone controls though connecting directly to the amp without the AV connected. Just using a volume control or autoformer, etc, is also called a passive preamp. No active to e Controls or line stage. Some people prefer this as there is less in the signal chain.
You maybe how it sounds. Notice the volume knob on the crown amp on top in the picture.View attachment 2245026
