IME SDA's sound mediocre at best without the connecting cable.
So you are saying they are mediocre at best speakers, and only the SDA effect makes them worthwhile?
My interpretation is that he said they "sound" mediocre at best not that "they are" mediocre at best speakers
An aftermarket blade/blade SDA interconnect cable is available here, https://www.midwestspeakerrepair.co...s/polk-audio-1/polk-audio-interconnect-cable/
The speakers will play without the cable, but and that's a huge BUT, you will not hear what makes SDA speakers special. Therefore, not using the cable diminishes the overall performance.
FYI, you cannot use non-common ground amps with that speaker.
what exactly is a non common ground
Any amp that does not share a common ground between the negative outputs. True dual mono and mono block amps will never share the ground. There are also many standard amps that are not common ground. If in doubt measure the outputs.what is a non common amp never heard of that term
