Polk monitor 10s
I'm thinking around 500 or under but more if need be. I know one thing I want to upgrade or get I should say is stands for these
Ok, upgrade the crossovers. Sonicap caps and Mills resistors. Replace the binding posts and while you're at it dump the fuses. Measure the resistance of each fuse then add that value resistor in each circuit. Normally I'd suggest replacing the stock driver screws with Hurricane nuts and socket head cap screws, but that Mortite has been on them for so long you probably cannot get the drivers/PR loose.
Take a good bit of that money and buy some real speaker cable.
About the stands. There's absolutely no reason to use that short angled stand Polk originally offered. Instead, get some nice 4 post stands that bring the tweeter to ear height.
Maybe it’s just because of the perspective, but that cabinet looks deeper than the cabinet on my 10a’s.
Whats the cabinet depth on yours?
Man, I was thinking the very same thing! I bet those babies dig deep with that extra cabinet volume. Looks to be at least 1/3 more than any Model 10s that I've seen.
OP - that's a nice grab for a ten spot. The 1A fuse in all four locations won't hurt anything. Order the right fuses for them and feel free to use those in the interim. As long as you don't go crazy with the volume, you should have no fear of blowing them.
The cabinet dimensions are 11 inches in depth and 28 inches in height
Thanks for the advice I will definitely check around on those
What should he do about that small hole in the tweeter? What is the best way to repair it?
Yea, the center hole in those Peerless tweeters is by design. I remember seeing it on new Monitor 10's at my local dealer.
So, I'd concentrate on a recap. Tons on examples at the Polk Forum. Also, I'd pull the midwoofers and run a bead of glue around the magnets, as they can shift out of place on these older Polls. And here's some good sources for capacitors:
Parts Express
Parts Connexion
Sonic Craft
Madisound
Meniscus
So, I'd concentrate on a recap. Tons on examples at the Polk Forum. Also, I'd pull the midwoofers and run a bead of glue around the magnets, as they can shift out of place on these older Polks.
2nd that , it don't take a lot of jiggling around to make those MW 6500 mid-woofer's magnet to shift and lock up the voice coil , I've cleaned with acetone then used JB weld in 4 equal spots on the pole-piece plate and on the basket plate (top and bottom of magnet)
I upgraded the tweeters on my 10b’s, and really don’t notice too much of a difference. Do twitters need a break in period? The old tweeters had a 1988 sticker in them... any thoughts? Thinking about the crossovers next, but if I couldn’t tell on the tweeters.... maybe my ears need an upgrade...
What model were your old tweeters and what did you replace them with? Without that info, there is no way to say if the new ones should sound better.
Definitely replace the caps. Recapping should be the first thing done to old speakers before replacing working tweeters.
Something is seriously wrong if you couldn't hear the difference.
