gburnham2004
I don't know what an stv3h is. OK I did see a braided sleeve over the wires, will look at it closer. The glue is for what purpose?Very good job cleaning those contacts. I believe it's silver oxide. Contact cleaner to the contacts inside the moulded housings.
Apply glue to where the solid wires enter the body of the stv3h, although they are covered by the braided sleeving but you can pull it back a bit to apply the glue and let it go back into position and let the glue dry.
I sprayed D5 into the plastic housings, I did not have anything small enough to penetrate the housing to wipe them out.
