I recently installed two high quality stepped attenuators. One of them has started popping when I rotate the attenuator. The others are dead quiet when I rotate them. I know that this can be caused by dirt or a weak wiper, but I don't think that's the problem. I think the attenuator is fine. In time, I will probably switch it with its mate to see if the problem follows. In the meantime, I suspect there can be circuit or grounding problems that can cause this. Does anyone have any thoughts on this?
