This is a continuation of some posts about a ported LaScala in the "Input sought re: tri-amping La Scalas and going with active (DSP) networks" thread.
If you have an older LaScala with open back and your plan is to remove the "dog house" cover inside the open top and then use the additional air volume and make a rear panel that is ported, you will have approximately 4.5cuft to work with as far as box tuning. Two 4" (diameter) x 7" long will tune a 4.5cuft enclosure to 30Hz.
Here is the TF1525 simulated in WinISD using the 1525 pdf specs and some PEQ to optimize the response:
PEQ - 35Hz, Q=1.4, Gain=6.5dB
PEQ - 80Hz, Q=1.4, Gain=-2dB
I'll try and post the Horn Response simulation once I determine it is accurate. I'm much more versed at bass reflex using WinISD than Horn Response.
