Balifly
Listening
Earl, do you need a RXL Improved (stylus for the XLM Mk II Improved), by any chance?
I have only one - ADC 250XE.
Trying to stay away from ADC for now.......
Thanks for asking! :thmbsp:
Trying to stay away from ADC for now.......![]()
boreas: If you think of it, start to collect some of the various products that claim not only to clean but also rejuvenate or restore rubber parts. Motorcycle people use the xylene + oil-of-wintergreen method to soften old carburetor boots. Either way, you've added something to the solution by molding the softened rubber so the repair is more useful and, dare we say, permanent.
I'll start by saying that this may not apply to all styli. Differences in the material used for the suspension bushing may result in different, even disastrous, results.
Okay, the subject of the experiment was a used ADC RXM-I (114-DEC). It came to me mounted on an ADC Integra integrated headshell and cartridge. The suspension had largely collapsed. The cantilever wasn't completely bottomed out but it was close. Since the stylus tip showed only a little wear, I decided to try to resurrect it.
Based on some erroneous information on the interwebs, I chose to treat the bushing with WD-40. I had read that the principle ingredient of WD-40 was fish oil and I thought that would be relatively benign. Turns out, however, that WD-40 is petroleum based.
Too late! I had already applied some to the suspension so I just went with it.
Here's what I did. I took a piece if paper and folded it onto a small shim which I then slipped between the cantilever and the stylus grip. This raised the cantilever significantly. I decided to raise it past the point where I believed it should be, thinking that it would slump back a little when the shim was removed. I was right.
After I inserted the shim I sprayed a little bit of WD-40 into a bottle cap and dipped a very small paint brush, about 1/8" wide, into the WD-40. I then proceded to apply WD-40 to both sides of the bushing. (This isn't always possible. On some styli all you can access is the front of the bushing.)
After about an hour I reapplied the WD-40 and, after another hour, I applied more. An hour after that I removed the shim and cleaned off the excess WD-40 with a dry Q-Tip. The stylus didn't spring back on its own but when I pressed on it it did, just a little and just where I hoped it would go. Since then, time and more pushed has made no additional change. I think it worked. The test will be when I listen to it, which I'm about to do.
John
I think John just did this for the Halibut.
I used to have that test record for my III and became interested in the music of Lee Holdridge because of it.
"Mas Que Nada" was already a favorite, and it's interesting now to hear the obvious tape distortion in that recording, one that was supposed to be so clean that you could easily tell if your cartridge was mistracking. Nope, some of that is the 1965 tape overloading. It's probably easier in the orchestral bells track to hear the separate sound of the cartridge misbehaving.
WD-40 seems squared away and vindicated, at least for now. I'm going to follow the siren song of Lestoil and see what that does for a certain 614-DQ.
I have recently purchased a NOS stylus for my Empire 888-TE that has significant sag. May have to see what I can do.
...I chose to treat the bushing with WD-40. I had read that the principle ingredient of WD-40 was fish oil and I thought that would be relatively benign. Turns out, however, that WD-40 is petroleum based.....
John
It certainly is worth a try, if only as "proof of concept". Whether the stylus gets put in service will, of course, depend on the condition of the diamond.
If you do it, please report back to us. Unlike the ADC, the Empire bushing can only be seen from the front. That makes applying WD-40 to both sides difficult or impossible (unless you squirt some down the hollow shank). Also the busing material may not be the same as the ADC's and may not like WD-40.
All in the name of science!
John
So help me understand....the wd40 tightened up the suspension because something in it softened/conditioned and tightened/firmed the rubber?
Wow. At the upper end of recommended weight, the NOS stylus/cart is nearly touching the record. Very anxious to try this.
