No, I'm talking about hum coming out of the speakers, not fan noise. They always seem to hum.
"inserted" noise from noisy front end gear, poorly shielded or terminated cabling, ground loops, poor house grounds, dirty mains power, RF from dimmer packs, etc. etc.. In a portable PA system the opportunities to induce unwanted noise are almost limitless. However, i always managed to keep mine pretty much noise free after i built my own mains power distribution and connected directly to the incoming house mains....you walk past a PA system at a bar, club, wedding etc. and there's quite a hum coming out at idle...is that not noise? Is it coming from somewhere besides the amp then?
I gotta ask this question that I'm surprised no one has yet...
um.. what the hell kind of speakers are you building that will "Require Up To 400 Watts"? and rms at that?????
Will these be very hard to drive loads?
Just because a speaker can handle it, doesn't mean you need it...
I've got 700 watt speakers I'm running with about 350 per channel, and I can't even begin to think about adding that much power to them without pissing off half my neighborhood, and that's being serious...
Even to hit 120db in my livingroom which is INSANELY loud, I'm using about 25 to 30watts on my mains, and about 150 on my subs.. or at least a close guess..
This may very well be true where "form" is concerned.You have totally different goals when constructing a PA and hi-fi amp.
An amplifier that itself introduces noise(easily audible amounts) in the signal path is either in need of service or a very poor amplifier.
You get better results at low volumes with a lot of idle. I would never use a PA amp though, not built for the purpose. You have totally different goals when constructing a PA and hi-fi amp.
I´d go for a NAD 208 or Pioneer M90a if I would need another one.
Nad 208 gives out several thousand watts at 1ohm, clean, transparent sounding as well.
.....Welcome to AudioKarma.org, Avicularia from The Netherlands....I have respect for a man who believes in Bose 901's and the Bose 1801 amps.....Am i right in assuming you are looking to power 2 sets of Bose 901 series 2 continental ?
If so,you might want to consider a Bose 1800 amp or two ,any series but 4 is best i heard and series 6 is most powerfull,build for the job and sound great.There`s a series 6 amp on ebay at the moment for 32 $.
To bad i live in the Netherlands.
I have three of these,two series 3 and an original series,the 2 series 3 are also supposed to be driving 2 sets of 901 ,currently saving up to have my second set 901 series 3 fitted with series 6 drivers.(recently bought the series 3 amps and had them fixed,bad speaker relays)
( i live half a hour drive from european hq,they have a service centre,i brought my 901`s and left one hour later with fixed 901`s,brought my 2 series 3 amps,fixed within three days,they know me by name,service is great !)
In my opinion these are the best amps for 901.
If i`m mistaken,you still might want to consider them,because series one bridges easily to some 500 watts @ 8 Ohm.
im looking to buy a power amp, to possibly run 4 speakers for my stereo build,
im not opposed to using multiple amplifiers either, the speakers im thinking of building will possibly require up to 400 watts rms at 8 ohms, i may scale this project down a bit. but does anyone here have any suggestions of stereo power amplifiers that may fit the bill? im looking at professional PA amps to be more precise. but im open to suggestion, im just really not sure where to look.
here is one example of something ive been looking at: http://www.qscaudio.com/products/amps/dca/dca4/dca4.htm
NAD makes excellent amplifiers, excellent sound, great dynamic headroom, and reasonably priced.
...without spending a fortune for it. you also need to be mindful of impedance, especially if you plan to run more than one pair of speakers. i have also never heard of QSC, so not sure if you would be very happy with the sound quality.
