MrHeadfirst
Lol, right on!
Why exactly? If you're on about being quiet in terms of hiss, I run a pro amp - a Citronic beast, which is dead quiet even with the preamp maxed out. Much more power for your money with a pro amp.such as the adcom 5500s which are VERY powerful and reliable plus quiet. pro amps are best left to the pros and their applications.
such as the adcom 5500s which are VERY powerful and reliable plus quiet. pro amps are best left to the pros and their applications. check out audiogon for adcoms. buying new wont break you either.
the 5400 is also quite powerful even at its 125wpc! heres one i found at a great price:
http://www.wildwestelectronics.net/gfa-5400.html
5500 at amazon/J&R:
http://www.amazon.com/Adcom-GFA-550..._m=ATVPDKIKX0DER&pf_rd_r=08TQ1AGP8YXJKAPG5D31
i have personal experience with these amps, they really KICK.
.....feel free to buy as many Adcom 125-watts-a-channel amps as you wish, HiFiTommy....only $600 a throw plus shipping....for $600 a throw and shipping, you can get four times the clean watts with QSC and Crown....I'm sure the Adcom sounds very good at 125 a channel, but....Tommy, if you're knocked out with the Adcom, I can certainly applaud that feeling.....i am sure it sounds ok. i need more than ok. adcoms stand up well in high end systems. not maybe as well as mark levinson or krell but thats another level.
the finer the glass is ground and the cleaner it is, the more you see. the same goes for audio.
Unless it's a 454 cid ....or the 507, marine.will enlighten you. you cant just pronounce that your system is high end. experience will work the wonder for you.
nobody is saying these systems dont sound good, but they will prove to not be refined sounding. there are many factors and when they come together in a system, it will be obvious and a revelation.
there are some pretty nice Chevys but they are NOT Lamborghinis nor Lotuses.
lotus and lamborghini are widely spaced in price but both handily outperform any chevrolet.
.....you make a valid point, HiFiTommy....do the Adcoms sound "that" good, for well under $1000?....can you compare them with McIntosh?.....maybe listening to some real high end systems will enlighten you. you cant just pronounce that your system is high end. experience will work the wonder for you.
