Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
The move to the new server is done. There are some software and database maintenance updates in process. This has us passing the hat around to help out. We appreciate any donations. Seriously, even a dollar helps. The payment page may be found here - https://www.audiokarma.org/support.html
Just a quick question..... when using the preouts on a receiver, does the amp section in said receiver get "used" or how should I put it..... less wear and tear???
The power amp section would still be powered up, but it would be just at idle (no current draw from a speaker load), so heat and wear and tear should be minimal.
I thought so, but figured I would check.i was using an amp with a Concept 2.5 and the little sucker seemed to get quite warm still... I am using a Pioneer vsx-d1s at the moment and figured that less heat output in that beast , the better longevity for it. I'll just have to try it out and do some testing I guess
It will still be running at however much current it uses with the volume all the way down. it will make heat. Depending on the unit, it will make a little or a lot. The further into Class A it is biased, the hotter its going to run. If the bias isn't set right, it may run hotter than it should.
