bowtie427ss
Lunatic Member
We'll play with yours first since you posted plenty of it for all to see.If you look at the specs of drivers at parts-express.com you see that woofers have an efficiency of 85 dB/m to 90 dB/m for the most part, and mid drivers lower. Tweeters often between 90 dB/m and 95 dB/m. Yet, most speakers you can buy in the big box stores, fit with cheaper, less efficient drivers, often read 93 dB/m or so on the protective boxes. The only way that can be achieved is if the producer attenuate the tiny crappy tweeter poorly and uses the highest reading the system can produce. Imagine that, a 85 dB/m woofer and a 93 dB/m tweeter. No wonder these audio forums are spilling over with people who ask for help from people like me to tweak their crossover to produce less treble. A speaker for the home stereo, that has a serious crossover, don't get over 90 dB/m.
But many of you are so sold about the idea 93 dB/m is real and it is good, I can do nothing for you. You are listening to crap and you don't even know it. Carry on. Go play with your poop, who ever that was.
You need to find a different forum. You know not of what you speak.
Your urge to post and lack of audio knowledge combined with your ability to read catalog pages without understanding their contents has you in WAY OVER YOUR HEAD.
For the benefit of the OP i would suggest that there are basically two different forms of "power hungry". There are loudspeakers with low sensitivity that simply require more voltage to achieve a given SPL level than a more sensitive design. Then there are loudspeakers that are more "reactive" loads which may have high current demands and impedance curves with a fairly broad swing.
Poll the favorite loudspeakers of AKers and you will find representation across the spectrum, from the lowest sensitivity acoustic suspension monitors to horn loaded mains of the highest sensitivity, stats, planars, and other unique designs that present loads from almost completely capacitive to purely resistive. Different amplifiers and different speakers combine for different results. Nothing substitutes an audition. But arming yourself with some empirical data on the components you're considering can help you make somewhat accurate predictions of how certain components might play together.
Very entertaining post.
