That would work for me. You may have to use the balanced output if you have ground loop issues with the sub woofer . I just hope the out puts 1 & 2 are isolated from each other and just not in parallel with an on and off switch.
What I do since I have two power amp/speaker setup on one preamp (C100)
My Velodyne FSR-18 is on the "Main Output", it's always hot and if I don't want the sub I turn it's own power swtich off.
1&2 outputs are switchable so you can have either or on or off, and both on if you want. This is how I select between my SS and Tube amps in my system but yet I can always have the sub with both amps.
