I'm curious about the best way to hook up a powered subwoofer with a pair of smaller 2-way monitors...in a 2-channel specific setup. :scratch2: Opinions and facts are both welcomed in this discussion.
-->My goals: 1) To get the best possible sound quality. 2) Maintain tonal balance/sonic signature between my integrated amp, the monitors and powered subwoofer (if possible).
Here's my powered sub amp...it has both preamp AND speaker level connections. I replaced the 5% resistors in the speaker level connection with 1% precision resistors. (excuse the dust/dirt; old pic, now clean)
So, I have 2 options on how to hook up the speakers...
1) Speaker level connection: wire from integrated amp speaker outputs to the sub-amp > then from sub-amp to monitors. (see below pic)
2) Preamp level connection: interconnect from pre-out on integrated amp to rca's on sub-amp. Wire from integrated amp speaker outputs directly to monitors. (see below pic)
At this point, I'm leaning towards the first option, speaker level connection. Why? I'm hoping that the tonal balance/sonic signature of my integrated amplifier will be heard through the entire frequency range of these speakers and NOT just the monitor section. I'm not sure if this is even possible, which is why I'm posting this thread.
I'm also thinking that this choice would affect the 'monitor & sub' crowd more than the 'full range & sub' crowd...since you won't need to create as much mid-bass with your sub when used with large full range speakers.
What do you guys think?? :scratch2:
