My current project is an approximately 20' privacy fence. The 20' will be comprised of 10' and 6' sections and a 4' gate.
For anyone with knowledge or experience, here are some of the questions floating around in my mind at the moment
GATE: Is it common practice to custom to build the gate? I know that hardware is available for mounting, latching, and somewhere I have seen special tensioning hardware that is intended to keep the gate square, i.e. prevent drooping of the unsupported end. Does anyone have recommendations for, or warnings against, specific gate hardware?
HOLE DRILLING: I intend to use a powered post hole digger. The posts will be 4x4 treated lumber.
How large should the diameter of the hole be to set 4x4 post? Should I dig deep enough to put a few inches of gravel beneath the bottom of the post to assist with drainage? How deep should the hole be, or I suppose this might be dependent on my geographical location?
Any tips for operating the powered hole digger?
SETTING POSTS: Mix concrete first, or pour it in dry then apply water with a hose?
SECURING POSTS WHILE CONCRETE HARDENS: Would it be best to set each post independently? If so, how would I secure the position of the post while the concrete hardens?
Or might it be better to assemble each fence section (just the posts and cross pieces, not the slats) first, making it easier to keep things square? But if I did it this way, there would still need to be some way to secure the section while the concrete hardens.
I will be digging through google searches and likely many youtube videos searching for answers to these questions
And will be interested in input from AK's DIY gurus
