Actually in that rig I'm using custom (as in I made) balanced interconnects with the mighty fine Belden 1800F cable and Neutik XLR connectors. No adapters, per se.
But, yeah, I use RCA to 1/4" TS adapter cables to connect unbalanced consumer gear to the pair of parallel-mono strapped Crown Microtech 1200s that I sometimes use to drive my Thiel CS3.6s. Works great, other than the fan noise you can hear at low volume. Too bad those Microtechs and the Macrotechs use those fanformer cooling fans. There are no good low noise replacements like the mods I did to the QSC fans.
Here's the stack in my garage I use for running the pair of JBL SR4719X subs and SR4732A tops in biamp. I've run that too with a consumer preamp. Works just fine, but I do tend to use a Yamaha mixer most of the time because I just leave that in the garage with all the rest of that stuff. Made for a great party system, but I don't do that much big partying anymore.
Here's the stack in my garage I use for running the pair of JBL SR4719X subs off two of the bridged CE4000s and SR4732A tops in biamp from the QSC PL3.4 and PL236. I've run that too with a consumer preamp. Works just fine, but I do tend to use a Yamaha mixer most of the time because I just leave that in the garage with all the rest of that stuff. Made for a great party system, but I don't do that much big partying anymore.
plug it in, i can tell how it should sound by the crown amp owner knowing the frequency of the vocals and guitar competing for space in the mix.
