radioactive
tube gear fanatic
if you have a cellphone with a good camera there are apps that allow you to use your phone as a scanner and convert your pictures to pdf.therescsome freevones and some you have to pay for.i use a app called tiny scanner .no need to buy a scanner unless you need one for everyday use.i use the app for mostly manuals and it seems to do a good job from what i have tried so far.you even get to choose the format a4,etc..Thanks, sadly the HP Flatbed Scanner I used to use only had driver support up to Windows XP, when I switched to Windows 7 the scanner became inoperative, I have since changed again to Windows 10.
The scanner went to the recyclers ;( and I have so little use for a scanner that I haven't bothered to get a replacement.
