Super Noob
Look what just landed in my work room... it’s a monster. Time to start poking around.
Here is the update... few posts to follow.
Pop the lid and noticed two things:
1) 220uF cap replaced with some cheap 100uf caps wired in parallel
2) Relay contracts jumped / bridged.
Here is the deal, the amp board is quite a tightly tucked board on the heat sinks. Was able to suspend heat sink from the chassis and get good access. One thing to note (as well) if anyone ever decides in the future to tackle this thing, there are no bleed resistors on the main filter caps (so you will need to bleed) before working on. I installed some inexpensive 1/4 watt 18K resistors until I got the new filters in. I enjoy the process and the seeing completion of the work, but no markings on the boards made troubleshooting more difficult and errors at least four times more likely.
Okay I am not MTF, Echowars, Kevzep, or any other stud you have read about here, so I took me awhile to track down the reason the relay was jumped out. I checked all the transistors and diodes (a few times) = all checked out fine. Obviously power (voltage) was not in the transistors in the protection area of the relay circuit. After a few hours and night sleep, I found that resistor R48 was open. Print showed this a 27K... found that the bad resistor was 21K. Anyways in this case = I stuffed in 27K per the print, and we were cooking with grease. After that was fixed, the amp board was full recapped, new trimmers, new relay, and fresh Wakefield paste.
Before:
After:
Had to come back in here after I got my filters = was missing two caps (not in stock -some low value high voltage caps), but the last picture shows the proper caps in as well as R48 changed.
I have plenty of stock on hand...Hi , in this picture you have used a mix of caps ? would you remember what makes you have used because I would love to use one or two makes only ? ....Did you order parts from Mouser ? cheers Matt mattsgpovan69@gmail.com
Super Noob, thanks for a great project writeup! I'm pretty new to restoring vintage stereo equipment, and I have a question. What are the bypass caps for, the ones you added to the main filter caps? I understand that the bleeder resistor drains the charge from the filter cap when the receiver is powered down. Do the bypass caps play a part in that?
Btw, I'm currently restoring an Akai AA-1150. Its internal layout is different from the AA-1200, but I picked up a lot of concepts and hints from your writeup.
https://audiokarma.org/forums/index.php?threads/filter-caps-bypassed.336048/
They may not make a difference... but I have seen used by Sansui and some of the Gurus here. I typically use 2.2uF as a standard. Some say ~.01% of filter value.
Absolutely wonderful job! Well done! I really like the old Akai stuff .... I've yet to experience a 120 wpc model, however.
Super Noob, the dial LEDs in these are AC or DC? If AC did you include a diode rectifier & capacitor on the supply?
LittleBill, I've got an AA-1150 that I'm going to start on. It's got a pretty massive 'thump' on power-up and power-down.
