Thanks! So, did you use 10 uF 100V?Typo… nice catch.
Sorry.
Onkyo adjustment procedures are one of the muddiest around. I got simplified version for my TX-8500 few years ago, let me check and I will post it here. For now, 40mV idle current as per SM procedure is too high . Very difficult to adjust DC offset, no variable resistor and that jumper gimmick was never clarified to me. Just be careful, it is quite easy to short something there...
EDIT; that is what I got for idle current and was told to leave the rest alone:
Disregard the adjustment procedure. Measure the voltage across R39. Use R22 and adjust it for 10mV. Do the same for the other channel.
Advice comes from one of the engineers who designed the receiver. When I asked why SM was so confusing he answered, " I did not write it ".
Maybe one day I will get back at it…Lovely treat this morning to find this thread, I love your threads supernoob. Amazing stuff.
That is correct, measuring across R39 or ID and CT points would give the same idle current value. Service manual calling for 40mV is too high and would make receiver run warmer than needed. Which was probably the case when these were brand new. But 10mV recommended by Onkyo engineer was also absolute minimum. I have this one since 2014 (fully restored and recapped) and had a chance to observe the bias shift over time. I was always a bit skeptical about this 10mV recommendation and instead went for 15mV, and by 2018 is slipped to 8-9mV, almost 50% in just 4 years! And this drop did affect the sound, big time. Only when another 8500 arrived for restoration I realized something was off with mine. So I readjusted to 25mV and to this day (6 years) it dropped just 3mV. As a side note, I had a chance to work on another two 8500 (I) receivers, both being 100% original and intact. All of them, including mine before restoration, had a factory bias between 25-32mV. If we assume these were factory adjusted as per service manual (40mV) that shows the bias on this unit will most likely go down over time. I recently readjusted again to 25mV and will revisit it sometime in 2030 ;-)Interesting. The original spec 40 mV between ID and CT translates then to the same voltage drop on R39 and R41, which means 40/0.47= 85 mA idle through each of the output transistors Q12 and Q14... Maybe they cranked it up to make sure it meets the THD specs with a margin?
Super Noob, Really enjoy seeming / reading refurb projects like this! When you recapped (EC's only, pic looks like all EC's) the TX-8500 mkI fm/tuner board did it require any retuning or fm adjustments? If so, what was done? Thx, WaltIn my quest to NOT buy anymore 70s receivers / amplifiers.... I have relapsed again. My focus is limited = great value, typical larger WPC, not working. Have read a lot about the TX-8500 mkII Onkyo and wished to find one. A TX-8500 mkI popped up locally in non-working state = it must be fate.
Here is how she landed in the garage:
I suffer from too much gear... I find / I fix / I keep (maybe could be called hoard). I have moved plenty of gear on to friends and audio enthusiasts. When you have the time I have in these rebuilds, it is hard not to become attached to the gear. This rig will be gifted to my good friend "Tony" in the panhandle.
From what I have read online looks like Tom Ishimoto was involved with this rig and was available around 1978. The specs show 110 WPC, 8 ohm, .1% THD, 20 Hz to 20 kHz.
Many posts to follow walking through the rebuild / restoration. This is my hobby, and I like to document builds to help or motivate others in the future. Hope you enjoy the thread.
Don't forget that I am just a NOOB with a soldering iron and the internet.
