Project: SX-1250 (2nd Take)
I Should Stop Buying Vintage Units - What is My Problem?
  • Sick
  • Not Right Upstairs
  • Sucker to For What Lots of Folks Refer to as Junk
  • Easily Hypnotised By Brushed Aluminum
Results are only viewable after voting.
Film caps don't usually fail, unless there is a darn good reason to change them I would leave them alone. That is not a high voltage circuit that might have punched a hole through the dielectric film. Factory changes during production (unless major) almost never make it into field documentation.
I was thinking about better sound quality with the polypropylene cap . This cap is the input on the base of the first differential pair transistor .
>>>>>> It appears Pioneer may have had a parts shortage on this run. The 470 caps on this board caps are different one is the LL yellow and one the standard black color. Made July 1977 .
Wonder why the change from 2.2uf to 1uf .
Maybe a parts shortage, the -3db point is about 1 Hz for the 2.2µF, and about 3.5Hz for the 1µF if I calculated it correctly. Can't see any frequency response reason to change, they are just dc blockers.
Final Pics:
oJgdlxLpdFWMhjU58lfNRj0CCjVJ3zLlatggzuqBwiOH3b3TqUMip16hsya0GUgbud_Ut5vAUu64qRl1d0rEPV7VB_vfm2vZYSHQcHVqvlzrAfiEQF_d_ORjfOdCRlavZfhhYxzV5VFLId35gx-Zlu2kyPzf0JthbLAMX1_nZVem4g4h3GldibLNqu6SaVoK9yViIqsvKeTnauqvlNYgra3DXRDd2Be8g73V0N_oBipZs7aaRPwy6fBu06C5GPMTGEXU5cI04IF54qIJPpYUOfV9ioG6W_MoSYEgAnFpTAkbEUbdtbqweiOUasBX0M8BrAevmR1XXOdUayaG2Wt7Nfbx631GF_PlATwSwy9JgkKf0-Bw-qTAsE8y-32wDU6v5W-nEYOpCxKzXGGqljeDedit3MHTPH5MviM1aQe8iKZ2tfXEhs3JXZ-xZKOaVq_FJ2KmYngTAxmFZQad6xS98S_1FNr52q2W4d2piPHwZUpv4n4QhoXk8XrfFsf1RhTnk6j8XHWQaZKaweZkDE9UFQgWg_kvJGBt0XCxwNFyADempEmoaZ8ykhxp--Dt2OuXj8uP3Jhxg468TEFcH7AeNynlVg6eRzUOnzvcgApkCw0CbJ3gsULxW4a1482LXDWFZ6kZMy04Bjdlp3K2kNalHT36K5XJrpDY11xxN_hy2bZAMSOwZ9vSzEs_AlOu6ffJnJUKl97jC_PmvankBHNnrQHO=w1147-h861-no
Rr0aniid3l1KYf0pPST4EpvlpAZ7IMsrkv70UV4LLv8ZiuQlok23W0p6gUar5VgSgZ3fAmgtk8_1rTJ1GEnPGz19g7u6S1jwItHCtg2R2Lpj7orLraJv5B2nJExYPxDaVKaM7MhXgrAUmDr88LAT84iAWLUJZGZferMaA43b-ZBPQX-BHUmu195v7KUnyYpeHpDBhO0q56jbOHXlkizvCXYNrwxddHU8qmdmxwJa6wfta7GQSDmBtNFwtXBbD5hI-XeuGGNVMKFVdO71DxjAObby1MwnR9wUMzns8U81CG9v95to5rannUOPxSefd73uH53W8wRYUsy3PEsJ_Kh6QrweKT_TR7-u9wBloV9yJWpnxwaWuK0kXyIcUjXy4G_JySJmu1p1s_wEzzxLXp2c2Gew_cBZVW9mBSbJ6Xt8d83DTgyRddmvfFIH178ff2Yc-nGddWEKiPGXV2mCRM5meQcR0cqIGIj5zTNZ6gFk5RNRWf_qkEnVlid66NzmlxPlM92h_L4cjGfAkgTtx2x1IwolA5LhS-dIigooYMAs5CgiIEOnqnCFrmUzXCra8OsejJNlfBvpn3TBUrI8jXh575Nnd5_jRc2qBbC7WISQXRV4lDrKKXHkHARUjDms9zV2encALXOWQbYWfErSBJCO89o6wCq8THN1K4PuZnsO50Q6E0r045pgzGPYLh1cYuVrkBWGZaTLmynQqdPt60waVG8f=w1147-h861-no
oMNSy_VpkME72TwXZCng8rm1HogqQDoBwN7jJjoeKMN3ShY4gvFNLZr7X3RO2w_lK_TeQo9-HwKGNtf-90N-flmktVMsiubHHrsRD2JhPCbcSrRD47VuIKzOpV8E0Ihjjlmb_54Wnc75wKIAI0hMzqjpgj9Mf5iIJidtBJevLFixHySBuomi5jOBTk1sCHsDVRtwr439_ExxM3jYvgrnv619WgOjpoUUTe4h2K9d9TykYnac8SCP3LlCu78EOx2Deog_rAf0dKfMgLo8w1scUoUdnPRAu7Ufajg-PuYCreNTlC-cRVMOchIE1JRwBQ72eWyWjMGNfrnmXxTSuaHXf65Gi7vVVAChGRbTfmFinEzZCjIp0gqb7d0EWPHJS6WIulUX8u0TBbgvD4GE9nB-m5Lh2WJ8H-fMG7HZk26_k84FoaWDLWEijUQyk-pwsRy-1etXWXLRQltgSrU7bOC9VynWrnF3WG48v7WXsp1MlvCNk1-8h1IQYaHAbqbPwarq-LbnzlylrfxEgAQ12lPAcLAkxmEm1HSfkPvfLvKx427jbBOZm9n165WMNLepBKOvuCJ2PRgu6tTxm6UxFkmwwWLExdgUzulIAx7FvjMpwO9HHF2QhzPAjJVFsbGcT5pD87NA-PsFxBAL56p4AYXTq7Svr09W_t1OzoNsdXyIokiwkXTLEk_8ddOzrZpNqCN1fF_Qjo4GHt7wYCDsXyeQJsNJ=w1147-h861-no
9yguiXT_EhlErhaNenOaY4rmDs_NpuPMyOJzZVPn14tcqDNSJdHzL73UgByYY07QSVu9Hhd-pLZWRYMkJ_dlUKCP000N8E3TJznERe4aPRptdp7bhQD8n9TZKUj7PoukIUqL12fHoMXF7WZ0-21y348r3awnjFLZlMsAXRWNh8e0ngPZDjv-LSf71jUTV_h0oIbhFuv9fr_sxl-MPS8AcRfw6Kr6CBFG_Tm_Qf9j5oz48zcHG8XPGCntfn1a0FiqCWS94AEj1JgDt2PrpCcI4Oq_6ZYFgZhtUp4UR6qqaaRFeRroLTGd7KG2aZQKyTDaB2HdLYqS9w0b4cHMgUScy4JVu6301oQXRmoFUfYwl9vI66LhUUHowZi77kihRO2CGspvnu0daoNOnHwC0DlJcTRPpEX56O6z8uFHt81stvAtcavCFhTsd8Dh7rBB3dj5ky7i871nDHQDZCzkmuqxKnQMo9NSt8a7znkrq-IwRKxfeDh01IelodeIPhlL6tIgtoL2McOBJLW82Uf0JjAYuqzNP34lkj3XR8NJXjv0yHsHCfWkjQItfmLhm76ZpXeXqjrrk4W-dBLMgOp-XQOeKguwsKMoy-DmKkCaTm0o_bbLQDw1ZgUbxiZzQN72_4eMPgaXF1R46pzym3WpgH7xqdDSZPRUTiY3DF24QF5-1L2RaZfLbU9FwcLPpteKxhVRlPXEUt1YGlf7DHLN3k3JiPtk=w1147-h861-no
Looks as good as it sounds. Hope these posts inspire some folks to rebuild their SX-xx50 receivers.
Best Regards & Thanks for Viewing.
My Goodness, that is beautiful. What a labor of love.
Rumble? Rumble filtering? (phono)
That is as good a thought as I could come up with. When I got my NEW SX-1050, I also got a Garrard Zero100c. I bought a copy of Dark Side of the Moon that had a warped edge, like it had leaned at an angle in a hot environment. When I played it I could see the woofers motoring in and out on my Infinity Column II speakers. When I took it back for replacement the shop owner put it on his shop system and his woofers did not move. I am guessing that was about a 3Hz signal, but it was about a 1/4" hump in the vinyl. :dunno:
I'm done working on the boards time recheck and reassemble this Sx1250 and DBT test it . I did find a few discrepancies with tuner board BOM . C33,C48 . By looking at the finished tuner board picture they appear to be typo's.
I am restoring another SX-1250. I am at the equalizer board, what do you think about using one 10uf BP (ES) cap for the two 22uf back-to-back tantalum caps? FYI, I measured. The tantalum caps and they're @ 200uf.and 100uf, I used to different testers. I thought it was displaying NF. it wasn't.
I won't need the 50V ratting that the back-to-back caps have? I don't want play around with the uF I'm not sure what it will change.
When your are talking components in a design, specify the exact ones on the schematic, BOM rather than guessing what ones you are referring to
the two 22uf back-to-back tantalum caps meaning, C25,26,30,31, two 22uF/16V in series = 11.5uF/32V
if you want BP, then use 22uF/35V, 647-UES1V220MPM, its not currently EOL
https://www.mouser.ca/c/passive-com...citors-radial-leaded/?q=UES&capacitance=22 uF
Nothing wrong with using two UKL back to back either, need to check what's available now
This is the list I have, it old, probably derived from Mark and others, many Nichicon could be EOL, its been years
AWF-021-A: C11: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-021-A: C12: 470uF 6.3v CEANL: 647-UKL1C471KPD 470uF 16v
AWF-021-A: C17: 3.3uF 50v CEANL: 647-UKL1H3R3KDDANA 3.3uF 50v 505-MKS2B043301H00KI
AWF-021-A: C18: 3.3uF 50v CEANL: 647-UKL1H3R3KDDANA 3.3uF 50v 505-MKS2B043301H00KI
AWF-021-A: C25: 22uF 16v CSZA: 647-UKL1V220KEDANA 22uF 35v
AWF-021-A: C26: 22uF 16v CSZA: 647-UKL1V220KEDANA 22uF 35v
AWF-021-A: C27: 220uF 63v CEA: 667-EEU-FC1J221 220uF 63v
AWF-021-A: C28: 220uF 63v CEA: 667-EEU-FC1J221 220uF 63v
AWF-021-A: C29: 100uF 35v CEA: 667-EEU-FM1H101 100uF 50v
AWF-021-A: C30: 22uF 16v CSZA: 647-UKL1V220KEDANA 22uF 35v
AWF-021-A: C31: 22uF 16v CSZA: 647-UKL1V220KEDANA 22uF 35v
AWF-021-A: C32: 100uF 35v CEA: 667-EEU-FM1H101 100uF 50v
Right If two 22uf /16v =11.5uf /32v Shouldn't I use one 10uf /35V BP? Is 35V really needed here? What is the advantage of using back-to-back? I'm thinking a 10uf BP cap was too costly in 1978 and a film cap just too big. I thought I was clear on what caps, I'll put the numbers next time.
I stayed with the four 22uf/35v for C25,26, C30,31 .
I do have an DC offset problem. The DC offset is low but is fluctuating fast and I get a split second spike that gets higher over time, 15mV so far. My differential pairs hfe on the amps inputs are close within 6 or 7 points. Defeating the tone controls helps. Checking my work, any ideas?
