First off Redboy, two words: OUT...STANDING!!
My only little comment is about the volume pot. It is in the circuit, acting as a variable resistor so the signal still has to travel through while shunting more or less signal to ground, affecting volume.
A few issues come up with a carbon comp, stereo pot or any other similar type volume pots:
1. Tracking
2. Repeatability
3. Quality and conductivity of the resistive element in the pot
As the pot wears, tracking will eventually suffer, and so repeatability. After a few thousand turns, what was once an even 100k on either side may become 90k and 110k. Minor, but with all things DIY, it's all in the details...and those changes can affect separation and sound stage.
IMVHO, this isn't that large a problem, but there are some who are always looking for or creating solutions to problems which don't exist.
One solution is a variable attenuator--a pot with heavy connection pads and a single resistor for each signal path at every step of increasing volume.
At any point, it acts like a pair of fixed resistors in the signal path, is repeatable and durable in the extreme, good for hundreds of thousands, possibly even a million turns, all while always presenting a perfectly balanced signal input.
Is it necessary? Not when you're getting great sound out of $8 worth of components and a cigar box (LOVE the box!), just pointing out possible differences between volume controls.
Best,
John
P.S. Did I mention I love the box? I have several cigar boxes I use to store tubes, sockets, grommets, etc. and love 'em.
