OrphicTrench
Hey guys, I'm a bit at a crossroads here. Need some help figuring out where to go.
I recently moved to a smaller apartment and I had to send my ATC SCM20ASL Pro MkII speakers to my parents house, because I no longer have the room for them in a dedicated mixing/studio space.
I did manage to set up a system in the living room with a fair amount of acoustic treatment and all.
My current system is built around a pair of Elac Debut F5 (mk1) speakers and a Marantz PM7005 (which replaced the Rega Brio clamshell mk1, as it just wasn't enough to drive the floorstanders).
I have the opportunity to buy an ATC CA2 preamp (with phono stage) which would make it possible to use the active ATC SCM20ASL Pro MkII speakers and my Dynaudio 18S active sub. It would cost me 2000$, which is the same budget I was planning on spending on better (used) floorstanders to upgrade the Elacs eventually.
What I like about a passive system is that you press one button and everything is on and ready to go. With active speakers, you need to turn each thing one by one. There are more chances of forgetting things or having a flatmate turning things on/off in the wrong order and whatnot. It's also less stressful to have a cheaper system. With the ATCs plus the sub and preamp, we're talking about 10 000$ worth of gear... Not the same as my relatively cheap Marantz amp and nice big floorstanding passive speakers.
Long story short, I don't know if I wish to keep my ATC speakers in a box and upgrade the speakers later down the road, or get a really sweet (and probably overkill) preamp and have a complete high-end active system with sub and all. What do you think?
Right now there's a big hole in the lower mids (between 200 and 700 hz), but it's probably due to my room. The Marantz+Elac combo does sound great in the low end, but it's a tiny bit flabby/relaxed. I thought the Rega was too punchy for me, but now I'm in the opposite side of the spectrum. There's probably a bit more of fine tuning that needs to be done.
