Hello KeithD,
I hope you are moving forward with your restoration , I’m following with interest .
As you know I’m not a tech , so I’m actually waiting for someone who has knowledge about electronics to update/upgrade a similar or the same unit so they can explain to us what really happened there . Add to all this that my English sucks !
I would try to explain with simple words and how it’s in my head , hope it helps .
I would say with certainty that recapping the unit and placing film capacitors in the signal path made the biggest difference in sound quality ! The quadrophonic effect , I think is a different thing . The way that I hear it , is that nothing is happening at the frond speakers in term of separation, it’s just a stereo reproduction from the source as a normal stereo amplifier does , the game is at the rear speakers that produce that ambient sound , then all
4 channels are producing a sound stage in your listening space .
So if you want to bring up the capability of the unit producing this ambient sound for rear channels in addition of “clear” sound and separation you need to go through the Modules, IC’s and the photocells .
The photocells I think did the most big deference, if you ask me , almost equal was the rebuild of the modules/IC’s on the synthesiser board and last but not least the oscillator board .
Besides what I could hear , after replacing everything at the synthesiser board , I could see that even the VU meters for the rear channels was moving up and down individually rather than before that they were moving like it was a mono not stereo reproduction .
A tip I can give you , if you go down that road is that if you replace the Vactols be careful for the polarity of the LED . If you install it reverse (+ -) the transistor 2SC506 , in my case 2N3440 will start warming up fast , that will tell you that the polarity of the LED of the vactrol is incorrect , so I suggest keep your finger on the transistor when you tern on the unit .
Obviously I have no idea why this is happening, just letting you know .
I have seen your restoration threads in AK , I believe that this type of work would be a peace of cake for you and I’m sure you gonna make it look good too ( not like mine ) . The only little expensive component is the vactrols everything else is resistors , transistors and few film capacitors .
Hope I helped a bit !
Thank you for tolerating my English !!!
