I think that the NHT 3.3 woofer crossover is a good example.
It is redrawn at the bottom of this page:
https://syclotron.com/biamping-the-nht-m3-3/
L1 12mH and C1 are on the woofer, I'd probably put 1 ohm 10W in series with
cap and leave out the resistor in series with the inductor.
You cannot use design tables for a real woofer with an inductive input impedance.
The 1 ohm resistor helps to avoid peaking in the low pass response when the
woofer has an inductive input impedance. You could use a Zoble but the 1 ohm
is a nice simple compromise.
I don't remember what the input impedance of the Super Zero looks like so it
is hard to say what to use there, probably 100 to 200 uF. Your maxSPL will be
limited if you do not filter out some bass to the sats. Super Ones would be better.
Don't worry about using NPE caps most large 3 ways use them without any
problems.
problems.
