Hi guys. So I've looked all over the internets on this one and I haven't been able to turn up much. Here's the situation. I have an old junky Sherwood sub that sounds pretty bad. I also have an orphan RBH bookshelf speaker that sounds pretty good. It turns out the RBH was a prototype speaker that I'll never be able to find again, so no hope in completing the pair (I live in Utah, near RBH factory, found the speaker thrifting, emailed the company, etc.) So I had the idea to replace the junky driver in the Sherwood with the nicedriver from the RBH. Same size driver, fits theSherwood perfectly (the magnet is about ten times heavier though). So here's where I'm sort of stuck. The sub is wired for dual voice coil, but of course the RBH driver is not. So I wired the RBH with one set, and then just taped up the other set and mounted the speaker. I tested it out and it works, sounds better than it did, but I was just wondering if I wired this thing in the optimal(or only) possible way. Is there another way to wire this? If not, what is the result of leaving one set of wires unused? I'm really just looking for an explanation of what the heck is going in there given this particular set up. (Note: I know that at bottom, the fundamental point here is: there's no good reason to do this anyway, so who cares? But think of it like we're in the laboratory, and I don't care if we make a mistake for the sake of learning something new.
