I have a silver audioquest balanced cable that sounds great with one CD player, when used with a particular preamp and speakers. Switch the speakers to my Quads, and I have to switch the AQ silver cable for a Straightwire Crescendo XLR cable of the same length. OR, if I run a different CD player with the original speakers, I have to use the Straightwire cable, too. The silver cable ONLY works with that one combination. It leans heavily towards a detailed presentation, and with my slightly more rolled-off Sony SS-m7s, that detail is nice- it is all balanced out. There's synergy. With the Quads, I get detaill overload. Same with the other CD player, which is more detailed and can get bright with a bad matchup. Its not really rocket science- the cable that can be overly bright, goes with the CD player/Speakers that can both be a bit mellow. And so on. But cable synergy is there.
With the gear you're using I wouldn't expect to hear any difference.
As for the Roger Russell site. Thank you, but that only muddied the waters. I'm not so keen on his set up either, seems like a lot of unneeded stuff.
That would be my opinion as well.
I'm with JoeESP9, my background is also EE, and kicking and screaming about sums it up. I have monoprice interconnects, but will get around to building some of these:
http://www.laventure.net/tourist/cables.htm
Even if you do build them yourself the parts are fairly expensive... I am getting to the point where I think it's worth it to invest, as I've travelled a ways along the audiophile road and am quite convinced I'd hear a difference with the system I now have.
The Roger Russell thing (which btw has been pointed at over and over again in these debates) is out of date and out of touch with reality as far as I'm concerned, and I would disregard it if I were you. Just my opinion, based on personal experience.
However, I'm leaning towards the "they won't make a difference in your particular system" camp in this instance. Don't take that the wrong way, it doesn't mean there's anything wrong with your system as is, or that it doesn't sound great. If you decide to check this stuff out, I strongly recommend you buy used.
If you need shielded cables, for example, the Audioquest Copperhead is an excellent choice (I used to own a pair), and they are around $45 per meter pair new.
What a great avatar!
I used Kimber Silver Streak until a CB operator with an illegal linear amplifier started interfering with radio and TV reception along with my stereo. I was quite happy with the Silver Streak but the RFI became a problem. Complaining to the FCC wasn't much help. So, I switched to the DH Labs cables. They use Silver plated OFC Copper. I'm very satisfied with them.
A serious winter snow storm in 2009 solved the RFI problem by blowing the CB antenna to New Jersey. I had already started changing to the DH Labs IC's and continued until I had replaced all the Kimber. I wanted to be ready in case another storm blew the antenna back. While I was at it I switched from Kimber TC-8 to DH Labs Q-10 Signature speaker cable. It too is Silver plated OFC Copper.
Most people don't know that the electrons actually move along the surface of the wire in a spiral to reflect the sine wave, than just through the wire, like water through a hose for example.
Ok, I like the Monoprice premium interconnects. I've always had good luck with them and they are way better than what one can get from rat shack or the ones that come in the box with new gear.
I have also always disbelieved the hype about the uber expensive interconnects and speaker cables. I just don't see the justification for them.
That said though I am curious. I have recently had a 1 hour course in interconnect cables from a guy I met when I bought my Pioneer PL-530 and HPM100s from.
He works with cables a lot and he was showing me some and explaining them to me although I was grasping only part of it (It was a lot of info and such for an hour). He also runs them on his system which is fairly high-end to me, but it's not all that expensive. It's also separates.
Anyway, he was encouraging me to pick up one or two PBJ cables. They are the "budget line" from some uber expensive cable maker (I forget the name). Even though "budget" (I don't think $70 is very budget for one cable) they are still made just as well as the other more expensive models from this particular maker. He told me that if I hook them into where my most important interconnect would be I would notice a big difference.
Let's take money, personal preference and bragging rights out of the equation. Let's pretend I could easily afford these expensive cables. (Believe me, it's overtaxing my imagination on that one).
My question is this:
My modern system is not separates. I have an Onkyo TX-R705 with and Onkyo C390 CD player (decent dac in that thing), a Yamaha DVD player and a Sony TT linear tracking which I don't use anymore because it's cheap sounding. (It really doesn't sound all that good) I'm currently running 25 year old Kenwood towers which I got for a song back in 1985.Now with that gear would I really notice an improvement in SQ to make it cost effective for those expensive interconnects? If so, could you explain why? Also do you think the most important interconnect is between the receiver and the CD player?
OR
Am I already as good as it gets with the monoprice stuff I run.
I'm not sure that's an agreed upon phenomena...at least not at typical audio frequencies if it's skin effect you're referring to.
I would not use thin gage wires to try to reproduce instruments like drums accurately at good volumes, anyway. Just my observations.
The top word in this avatar means Radio and the second word below means Lamp. Pronounced Radio and Lampa! How do I know:scratch2:Not bad.
Give all the "manipulation" of the audio signal in the recording chain and production chain, it is difficult to say which cable is better or best.
