RogerALB
I acquired a Pioneer SX-680 that needs TLC, and I figured it would be a good opportunity to learn some new stuff. The situation started with a loud buzz from the speakers. I think there may be more than one problem.
In the process of diagnosing the buzz I discovered that R401 was dead. I replaced it. Today I found out that R341 (the PC Board Connection Diagram is hard to read, but it is 2.2ko 1/2w connected to the 4a fuse near point 9) is also dead.
The outgoing low voltage leads on the power supply transformer are pins 11 & 12 36.7v, pin 14 24.5v.
The voltages for the SSTK0039 units are a bit nutty with pin 1 24.2v on the left and 25.2 on the right; pin 34.2 on the left and right; pin 3 26.8 left and 26.4 right; pin 8 26.9 left and 26.5 right; pin 9 26.9 both sides; pin 10 26.9 left and 27.6 right. My understanding is that some of those voltages are waaaaaaaaaaaaaaaaaaaay out of spec.
But, what is really spooky is that I am getting 108v on both sides of R401 and at various points as I track the traces and so on. Obviously, this is not remotely correct.
My most recent thinking is that there is a voltage "leak" (call it a short if you wish) on the incoming side of the power supply transformer. I thought R341 (or whatever it is) might be the culprit, but I don't know. Then I thought that maybe the STK0039 units were bad (which I guess they are) and causing some sort of voltage irregularity.
Anyway, I am tracking and tracing and having a rollicking good time, too. Not really, but it is interesting.
Does anybody have a few ideas about what might be going on with this SX-680?
Thanks for considering.
RogerALB
RogerALB
