RogerALB
Well, I checked the 13.5VDC at the point indicated and it matched nicely. While I was at it I checked for the 30VDC at the red point and it was good, too. Both were point to ground.
I did change C405 the other day, as a matter of fact, so it is fresh as a daisy. I checked it again just now and it is the right one in the right place put in the right way.
RogerALB
OK, well, this is a cross between annoying and embarrassing frosted with bad news.Never fear over time things will slowly start to make sense, or your brain will explode and then it will all magically fall into place.
Let's have a look at the FM right now. The AM and FM section is powered by the +13 volt supply.
Check the blue point for +13.6 volts if it is not there step back to the red point for +30 and if still missing check the far right side (on the diagram) of R402.
If the voltage is there then check R402 for open. If open ask why would it open? Resistors usually open up because they have too much current pulled through them.
If C405 shorts then you have the full 34.5 volts going through it to ground, poof. There could be a short or low resistance in the circuits on the emitter side of Q401 drawing too much current, or some other reason TBD.
Ohms law for fun if C405 shorted out R407 would have the full +34.5 volts going through it back to ground (shorted cap). I=V/R
That would draw 734mA causing the resistor to dissipate 25 Watts of power, won't last long like that.P=V*I![]()
I decided to check various voltages, etc. in part because I was suspicious. The scoop is that when I test the speaker terminals I get 33VDC from the pin to the opposite pin, i.e. purple to black or blue to black. Black goes to ground.
Tracing the wires along I get 33VDC at the speaker on/off switch pins to ground. Also at the speaker protection fuses to ground.
The schematic indicates 12.v at 8ohm at the speaker terminals.
My question is, does this indicate blown STK modules? It correlates to the weird STK voltages mentioned previously.
Finally, this appears to have blown my left side speaker so I have to either track down junk speakers or dummy loads.
Advice and comments are appreciated.
