Rack Mount Handles
steigrafx
Member
I'm not certain, but I believe there are only two sizes of rack mount handles made by Sansui for their late 70's gear. Can someone tell me if the rack mounts for the AU-217/317 fits the AX-7? They all look about the same height.
Thanks,
Kevin
Thanks,
Kevin
Yes they are same for AU-217/317/AX-7
There are at least 5 different rackhandles. For the AU 117/317/AX7, for the AU 417/919, for the BA F1/SC5330, for the CA F1. The 5th one is for? I don't know.:no:
So then I was right -- there are only two sizes!
I had no idea there were so many different sizes. Thanks for enlightening me.
My SE-7 has different ones than my AU-919/TU-919 does, FWIW. They look like the same but one is plastic and the others are metal.
Yes they have different parts numbers as well.
Even rackhandles for AU/TU919 are different referring to part number.
Following information about the different sizes of Sansui Rack Handles can be found by searching AK:
1. Tiny for CA-F1 - these don't have actual handles but are mounting "ears".
2. Small for AU/TU- 117 217 317 AX-7.
3. Inbetween small-medium for SE-8 equaliser + D-350/550M cassette deck (and possibly others)
4. Medium for SC Casette Decks + SE-7 equaliser
5. Large for AU/TU 417 517 717 917 819 919.
6. Jumbo for BA-F1. + SC-5330 cassette deck
Most of them available in steel and plastic, see earlier thread(s) on AK.
-John-
Here the most SANSUI`s for rack mounting (with or without handles)
I think it gives a lot of different handles
Model/High/mm
RX-50/50
CA-F-1/60
TU-S5 (B)/83
TU-S7 (B)/83
RX-100/100
AU-117/110
AU-217/110
AU-317/110
AX-7/110
MA-7/Meter Amp/110
MA-7/Monitor Speakers/110
RA-900/110
SE-5/110
TU-117/110
TU-217/110
TU-317/110
D-350M (B)/128
D-550M (B)/128
SE-8 (B)/130
AU-D5 (B)/148
AU-D7 (B)/148
SE-9 (B)/148
RX-150/150
SE-7 (B)/159
SC-1110/160
TA-300/160
SC-3330/160
SC-1330/160
AU-417/168
AU-517/168
AU-717/168
AU-819/168
AU-919/168
SC-2110/168
SC-3110/168
TA-500/168
TU-417/168
TU-517/168
TU-717/168
TU-919/168
AU-719/168
TU-719/168
BA-F1/187
SC-5330/187
SC-5110/198
Information over all this you can find at my database:
http://new-hifi-classic.de/Gallery_MO/index.php?cat=66
Michael-Otto
Same height but the hole placement may vary. It can be metal or plastic as well.
Here are the part numbers for different models.
5390080 SC-1110
xxxxxxxx SC-2110/SC-3110
5396700 SE-5
5397100 SE-7
5396720 TA-300/500/TU-919/TU519/TU417
5396340 TU-717/AU919
5396350 AU117/217/317/AX7/TU217/TU317
5396700 AU117II/217II/317II
72963600 SC-1330/SC-3330
72964000 SC-5330
07712200 SE-8/D-350M/D-550M
07726700 TU-S7
07667900 AU-D5/D7/SE9
Wow, that's amazing. You people really know your Sansui's!
Thanks, Michael and Stene, for taking the time to reply. Have a great day!
Kevin
Adding CA-F1 and SE-9, almost complete:
Code:
 part number   hole placement                     Model                     high
    72 963 900  horizontally   CA-F1, RX-50                                 6,0 cm
     7 726 700     4,5 cm      TU-S5/S7/S9 (B)                              8,3 cm
     5 396 350     6,6 cm      AU/TU-117/217/317, AX-/MA-7, (RA-900? RX-10 11,0 cm
     5 396 700     6,6 cm      AU117II/217II/317II, SE-5, (RA-900? RX-100? 11,0 cm
     7 712 200     8,0 cm      D-350M/550M (B), SE-8 (B)                   12,8 cm
     7 667 900     8,0 cm      AU-D5/D7 (B)                                14,8 cm
     7 767 900     8,0 cm      SE-9 (B)                                    14,8 cm
                      ?        RX-150                                      15,0 cm
    72 963 600     10,0 cm     SC-1330/3330                                16,0 cm
     5 396 340     10,0 cm     AU-517/717/719/819/919, TU-717/719          16,8 cm
     5 396 720     10,0 cm     TU-417/517/519/919, TA-300/500, AU-417      16,8 cm
     xxxxxxxx      10,0 cm     SC-2110/3110                                16,8 cm
     5 397 100     10,5 cm     SE-7 (B)                                    15,9 cm
     5 390 080     10,5 cm     SC-1110                                     16,0 cm
    72 964 000     11,0 cm     SC-5330, BA-F1                              18,7 cm
The SC-5110 got no rack handles!
Dear Tinnkindling!
You are right. The BA-5000 and also the AT-15L are mountable. But the listings in this thread contain only the Rack Mounting Adaptors, f. e.
SE-9
... or ...
AU-D5/7
:wave:
What about the sansui AU-519, TU-519,
This is the same size as the TU/AU 517, 717, 519,719, 919 and EQs like the SE-7 and many other components. It's the most common size but the 519 had plastic handles like the SE-7, best replaced with metal ones. I had a mint AU-519 and my friend now has it, kinda rare and it was only around for one year.
